Introduzione
In this guide, we will show you how to remove and replace the Memory Module.
Parti
Nessuna parte richiesta.
    • Follow the instructions in Before Working Inside Your Computer.
    • Ground yourself by touching one of the metal connectors on the back of the computer.
    • NOTE: If you leave the area, ground yourself again when you return to the computer.
  1. Turn the computer over, loosen the captive screws on the memory module/Mini PCI cover, and then remove the cover.
    • Turn the computer over, loosen the captive screws on the memory module/Mini PCI cover, and then remove the cover.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
  2. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the module from the connector.
    • Remove the module from the connector.
  5. Align the notch in the module edge connector with the tab in the connector slot. Align the notch in the module edge connector with the tab in the connector slot.
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  7. Replace the memory module/Mini PCI cover and tighten the screws.
    • Replace the memory module/Mini PCI cover and tighten the screws.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
  8. Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
Conclusione
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 28
