Salta al contenuto principale
Dell Inspiron 1300 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1300 Hard Drive Replacement, Loosen the Captive Screws: passo 1, immagine 1 di 1
  2. Dell Inspiron 1300 Hard Drive Replacement, Lifting the Cover: passo 2, immagine 1 di 1
    • Lift the cover off the computer and set it aside.
  3. Dell Inspiron 1300 Hard Drive Replacement, Sliding the Hard Drive: passo 3, immagine 1 di 1
    • Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
  4. Dell Inspiron 1300 Hard Drive Replacement, Installing the NEW Hard Drive: passo 4, immagine 1 di 1
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
  5. Dell Inspiron 1300 Hard Drive Replacement, Replace the Cover: passo 5, immagine 1 di 1
    • Replace the cover and tighten the screws.
Conclusione
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,286
