Salta al contenuto principale
Dell Inspiron 13-7373 Daughterboard Replacement
Cosa ti serve
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: passo 1, immagine 1 di 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: passo 1, immagine 2 di 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: passo 2, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: passo 3, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: passo 4, immagine 1 di 1
    • Remove the daughterboard.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
84.850 Reputazione
215 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 316
