Introduzione
This back cover replacement repair is for the Dell Inspiron 13-7373 laptop. A repair like this is typically needed when there is damage to the back cover exposing components or when some components need to be replaced. If your back cover is causing reduced airflow or has sharp edges because it’s cracked or broken, you probably need to replace it. There is nothing unusual about this repair and requires no special skills to be performed.
Cosa ti serve
Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
Use an opening tool to remove the bottom half of the case from the laptop.
