Salta al contenuto principale
Dell Inspiron 13-7370 Fan Replacement
Cosa ti serve
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, immagine 1 di 3 Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, immagine 2 di 3 Dell Inspiron 13-7370 Fan Replacement, Fan: passo 1, immagine 3 di 3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: passo 2, immagine 1 di 2 Dell Inspiron 13-7370 Fan Replacement: passo 2, immagine 2 di 2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: passo 3, immagine 1 di 2 Dell Inspiron 13-7370 Fan Replacement: passo 3, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: passo 4, immagine 1 di 2 Dell Inspiron 13-7370 Fan Replacement: passo 4, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: passo 5, immagine 1 di 3 Dell Inspiron 13-7370 Fan Replacement: passo 5, immagine 2 di 3 Dell Inspiron 13-7370 Fan Replacement: passo 5, immagine 3 di 3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: passo 6, immagine 1 di 1
    • Remove the fan from the device.
Conclusione
Zayed Azam
Membro da: 05/16/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 753
