Salta al contenuto principale
Dell Inspiron 13-7359 Speaker Replacement
Cosa ti serve
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: passo 2, immagine 1 di 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: passo 3, immagine 1 di 3 Dell Inspiron 13-7359 Speaker Replacement: passo 3, immagine 2 di 3 Dell Inspiron 13-7359 Speaker Replacement: passo 3, immagine 3 di 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: passo 4, immagine 1 di 3 Dell Inspiron 13-7359 Speaker Replacement: passo 4, immagine 2 di 3 Dell Inspiron 13-7359 Speaker Replacement: passo 4, immagine 3 di 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: passo 5, immagine 1 di 2 Dell Inspiron 13-7359 Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: passo 6, immagine 1 di 2 Dell Inspiron 13-7359 Speaker Replacement: passo 6, immagine 2 di 2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: passo 7, immagine 1 di 2 Dell Inspiron 13-7359 Speaker Replacement: passo 7, immagine 2 di 2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Conclusione
Baylor, Team S1-G6, Johnson Spring 2018 Membro di Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 350
