Salta al contenuto principale
Dell Inspiron 13-7359 Cooling Fan Replacement
Cosa ti serve
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team S1-G6, Johnson Spring 2018 Membro di Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 658
