Introduzione
If you notice the screen of your Dell Inspiron 13-7353 laptop is damaged and needs to be replaced, this guide may help. This guide will show you how to replace the display screen in a few steps.
Before beginning the repair, turn off the laptop and unplug from the charging cord.
Cosa ti serve
Close the computer display and turn the computer over so that the base of the computer is facing up.
Remove the ten screws that secure the base cover to the base of the computer.
Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
Unplug the daughterboard cable in two places, then remove the daughterboard.
Unplug the fan cable.
Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
Remove the heat sink.
2 Commenti
Wow. Thank you so much. I will do this when I get my replacement screen.
Finally tried this and noticed you left out the most difficult part which is the part of putting on the actually replacing the screen. This is only for removal of the screen. And the instructions are definitely not the same backwards. You left out the part with the cable/wires closing with the hinges being the most difficult part. I actually forced the cable too much stripped the cable that goes around the new screen. Have to order new cable now ugh
