Introduzione
If you notice your computer programs or computer are slowing, then this guide may be able to help. This guide will show you how to replace the RAM in a few steps.
Parti
Nessuna parte richiesta.
  1. WARNING :  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer . After working inside your  computer, follow the instructions in After working inside your computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer . After working inside your computer, follow the instructions in After working inside your computer.
    • Close the display and turn the computer over
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
    • Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
  5. Before opening device, ensure that all data is backed up on a hard drive to prevent data loss. Loosen and then unplug the hard drive cable.
    • Before opening device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  6. Remove 2 M2 3mm screws, using the Phillips 1 screwdriver. Remove the battery.
    • Remove 2 M2 3mm screws, using the Phillips 1 screwdriver.
    • Remove the battery.
  7. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM.
    • Pry open the clips and remove the RAM.
Conclusione
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 127
