Salta al contenuto principale
Dell Inspiron 13-7352 Cooling Fan Replacement
Cosa ti serve
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: passo 2, immagine 1 di 2 Dell Inspiron 13-7352 Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: passo 4, immagine 2 di 2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: passo 5, immagine 1 di 2 Dell Inspiron 13-7352 Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,238
