Salta al contenuto principale
Dell Inspiron 13-5368 Wifi Adapter Replacement
Cosa ti serve
  1. Dell Inspiron 13-5368 Wifi Adapter Replacement, Wifi Adapter: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 9.6 mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 2, immagine 1 di 1
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 4, immagine 1 di 1
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery
  5. Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 3mm screw and the metal bracket that holds the network adapter card in place.
  6. Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 6, immagine 1 di 2 Dell Inspiron 13-5368 Wifi Adapter Replacement: passo 6, immagine 2 di 2
    • Pull out the network card.
    • To completely remove the network card, disconnect the two cords (white and black) from the adapter card. White on 1 and Black on 2.
Conclusione
IUPUI, Team S4-G4, Wilson Fall 2018 Membro di IUPUI, Team S4-G4, Wilson Fall 2018
IUPUI-WILSON-F18S4G4
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,748
