Introduzione
This is a simple step-by-step guide on how to remove and replace a screen display for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. This task requires a great amount of care because you are working with glass. The time needed to complete this task is approximately 10 minutes.
Cosa ti serve
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
Altre 2 persone hanno completato questa guida.
