Salta al contenuto principale
Dell Inspiron 13 N3010 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Turn the computer over.
    • Slide the battery lock latch to the unlock position.
  2. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Release Latch: passo 2, immagine 1 di 1
    • Slide the battery release latch to the side.
  3. Dell Inspiron 13 N3010 Battery Replacement, Lifting the Battery: passo 3, immagine 1 di 1
    • Slide and lift the battery out of the battery bay.
  4. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery: passo 4, immagine 1 di 1
    • Slide the NEW battery into the battery bay, until it clicks into place.
  5. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: passo 5, immagine 1 di 1
    • Slide the battery lock latch to the lock position.
Conclusione
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 177
