Salta al contenuto principale
Dell Inspiron 13 7378 Wi-Fi Card Replacement
Cosa ti serve
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: passo 1, immagine 1 di 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, immagine 1 di 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, immagine 2 di 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 2 di 2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Conclusione
Gateway, Team 1-3, Saknee Spring 2022 Membro di Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 284
