Introduzione
In this guide, we will show you how to remove and replace Memory Modules.
Cosa ti serve
Remove the screw that secures the memory module cover to the computer base.
Use a plastic scribe to lift the memory module cover up at an angle and ease the tabs out of the computer base.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the memory module from the memory module connector.
Align the notch in the NEW memory module with the tab in the memory module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Align the tabs on the memory module cover with the slots on the computer base and snap the cover into place.
Replace the screw that secures the memory module cover to the computer base.
