Salta al contenuto principale
Dell Inspiron 1210 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1210 Hard Drive Replacement, Removing the Hard Drive Cable: passo 1, immagine 1 di 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
    • Remove the hard drive cable from the hard-drive system board connector.
  2. Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: passo 2, immagine 1 di 2 Dell Inspiron 1210 Hard Drive Replacement, Lifting the Hard Drive: passo 2, immagine 2 di 2
    • Lift the hard drive out of the hard drive compartment.
  3. Dell Inspiron 1210 Hard Drive Replacement, Detach the Cable: passo 3, immagine 1 di 1
    • Detach the hard drive cable from the hard drive cable connector.
  4. Dell Inspiron 1210 Hard Drive Replacement, Remove the Hard Drive: passo 4, immagine 1 di 1
    • Remove the hard drive from the rubber case.
  5. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: passo 5, immagine 1 di 1
    • To replace the hard drive, replace the rubber case onto the hard drive.
    • Attach the hard drive cable to the hard drive cable connector.
  6. Dell Inspiron 1210 Hard Drive Replacement, Placing the Hard Drive: passo 6, immagine 1 di 1
    • Place the NEW hard drive in the hard drive compartment.
  7. Dell Inspiron 1210 Hard Drive Replacement, Attaching the Hard Drive Cable: passo 7, immagine 1 di 1
    • Attach the hard drive cable to the hard-drive system board connector.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,061
