Salta al contenuto principale
Dell Inspiron 1200 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: passo 1, immagine 1 di 2 Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: passo 1, immagine 2 di 2
  2. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Dell Inspiron 1200 Display Assembly Replacement, Releasing the Retention Tabs: passo 3, immagine 1 di 1
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Antenna Cable: passo 4, immagine 1 di 1
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  5. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  6. Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: passo 7, immagine 1 di 2 Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: passo 7, immagine 2 di 2
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  7. Dell Inspiron 1200 Display Assembly Replacement, Removing the Cables: passo 8, immagine 1 di 1
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  8. Dell Inspiron 1200 Display Assembly Replacement, Lifting the Display Assembly: passo 9, immagine 1 di 1
    • Lift the display assembly out of the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 225
