Salta al contenuto principale
Dell Inspiron 11z-1121 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 11z-1121 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: passo 2, immagine 1 di 2 Dell Inspiron 11z-1121 RAM Replacement, RAM: passo 2, immagine 2 di 2
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron 11z-1121 RAM Replacement: passo 3, immagine 2 di 2
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
Conclusione
USF Tampa, Team 1-5, Nance Fall 2016 Membro di USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 475
