Introduzione
The fan in a laptop is responsible for keeping the the laptop cool so that it can properly function. Without the fan the laptop can overheat or run slowly.
Cosa ti serve
Slide the latches outward to release the battery.
Pull the battery outward to remove.
Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
Start by prying the outer casing of the laptop using the plastic opening tool. Start from the bottom and work your way around the edges.
