Salta al contenuto principale
Dell Inspiron 11z-1121 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: passo 2, immagine 1 di 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: passo 3, immagine 1 di 1
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: passo 5, immagine 1 di 1
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: passo 6, immagine 1 di 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: passo 7, immagine 1 di 1
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: passo 8, immagine 1 di 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: passo 9, immagine 1 di 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 257
