Salta al contenuto principale
Dell Inspiron 11z 1110 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 11z 1110 Display Assembly Replacement, Dislodge the Mini-Card Antenna Cables: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  2. Dell Inspiron 11z 1110 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Disconnect the display cable and the camera cable from the system board connectors.
  3. Dell Inspiron 11z 1110 Display Assembly Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  4. Dell Inspiron 11z 1110 Display Assembly Replacement, Lifting the Display Assembly: passo 4, immagine 1 di 1
    • Lift the display assembly off the computer.
  5. Dell Inspiron 11z 1110 Display Assembly Replacement, Placing the Display Assembly: passo 5, immagine 1 di 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 11z 1110 Display Assembly Replacement, Routing the Mini-Card Antenna Cables: passo 6, immagine 1 di 1
    • Route the Mini-Card antenna cables through the routing guides.
Conclusione
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 277
