Introduzione
In this guide, we will show you how to remove and replace the Display Assembly.
Parti
Nessuna parte richiesta.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Disconnect the display cable from the system board connector.
    • Disconnect the display cable from the system board connector.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the two screws (one on each side) that secure the display assembly to the computer base.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  7. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Connect the display cable to the system board connector.
    • Connect the display cable to the system board connector.
  9. Route the Mini-Card antenna cables through the routing guides on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  10. Connect the Mini-Card antenna cables to the Mini-Card(s).
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Conclusione
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 32
