Salta al contenuto principale
Dell Inspiron 1100 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
    • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
    • This step does require some force. Be careful to not bend or break the plastic face plate.
  2. Dell Inspiron 1100 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 1100 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws securing the keyboard.
  3. Dell Inspiron 1100 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift up the keyboard to expose the ribbon header on the motherboard.
    • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
  4. Dell Inspiron 1100 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 1100 Keyboard Replacement: passo 4, immagine 2 di 2
    • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
    • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 469
