Introduzione
In this guide, we will show you how to remove the Display Assembly.
Parti
Nessuna parte richiesta.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
    • Follow the instructions in "Preparing to Work Inside the Computer."
    • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
    • Close the display.
    • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
  2. Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
    • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
    • Remove the two M2.5 x 5-mm screws from each hinge bracket.
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Lift the display assembly up and out of the computer base.
Conclusione
Terrence15
Membro da: 18/12/2017
70.198 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 33
