Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit. Use your screw driver to remove the plastic cover  in the center of the laptop.
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. Use your metal pry tool to pry around the laptop until the two pieces separate. There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  4. Remove the speaker plug from it's socket. Lift the speaker assembly from the case.
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Conclusione
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
