Salta al contenuto principale
Dell Inspiron 11-3164 Screen Replacement
Cosa ti serve
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: passo 1, immagine 1 di 2 Dell Inspiron 11-3164 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: passo 2, immagine 1 di 1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
Conclusione
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 161
