Salta al contenuto principale
Dell Inspiron 11-3164 Mousepad Replacement
Cosa ti serve
  1. Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: passo 1, immagine 1 di 2 Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: passo 1, immagine 2 di 2
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Mousepad Replacement: passo 2, immagine 1 di 2 Dell Inspiron 11-3164 Mousepad Replacement: passo 2, immagine 2 di 2
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Mousepad Replacement: passo 3, immagine 1 di 1
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Mousepad Replacement: passo 4, immagine 1 di 1
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Mousepad Replacement: passo 5, immagine 1 di 3 Dell Inspiron 11-3164 Mousepad Replacement: passo 5, immagine 2 di 3 Dell Inspiron 11-3164 Mousepad Replacement: passo 5, immagine 3 di 3
    • With tweezers, disconnect the keyboard cable
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • Gently remove the mouse touchpad.
Conclusione
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 169
