Introduzione
Replacing a motherboard is a multi-step process. All devices within the laptop must be disconnected and some must be removed before the motherboard can be replaced. So, the very first step should be running diagnostic on the computer. Dell has a website that can diagnose the problems automatically by clicking here.
Cosa ti serve
Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 60 mm screws.
Remove the plastic cover to unveil the final screw holding the front and back frame together.
Remove this last screw of size 60mm with the J1 phillips head bit found in the approved iFixit toolkit.
