Salta al contenuto principale
Dell Inspiron 11-3162 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screw: passo 1, immagine 1 di 1
  2. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Display Cable: passo 2, immagine 1 di 1
    • Slide and lift the display-cable bracket off the system board.
  3. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: passo 3, immagine 1 di 2 Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: passo 3, immagine 2 di 2
    • Open the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Palm Rest: passo 4, immagine 1 di 1
    • Open the palm rest and keyboard assembly at an angle.
  5. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  6. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Assemblies: passo 6, immagine 1 di 1
    • Slide and lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 11-3162 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 1
    • Place the NEW display assembly on a flat and clean surface.
  8. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Holes: passo 8, immagine 1 di 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 11-3162 Display Assembly Replacement, Securing the Cable: passo 10, immagine 1 di 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  11. Dell Inspiron 11-3162 Display Assembly Replacement, Sliding the Display Cable: passo 11, immagine 1 di 1
    • Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
  12. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Hole: passo 12, immagine 1 di 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  13. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screw: passo 13, immagine 1 di 1
    • Replace the screw that secures the display-cable bracket to the system board.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 501
