Salta al contenuto principale
Dell Inspiron 11-3147 Replace the Battery Replacement
Cosa ti serve
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: passo 2, immagine 1 di 1
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: passo 3, immagine 1 di 1
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
William Brum
Membro da: 03/04/16
737 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,462
