Salta al contenuto principale
Dell Inspiron 11-3147 CMOS Battery Replacement
Cosa ti serve
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 1 di 2 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 2 di 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: passo 2, immagine 1 di 1
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: passo 3, immagine 1 di 1
    • Remove the CMOS Battery
Conclusione
William Brum
Membro da: 03/04/16
737 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 3,052
