Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
Cosa ti serve
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at an angle and press the memory module down until it clicks into place.
