Salta al contenuto principale
Dell Inspiron 11 i3147 Camera Replacement
Cosa ti serve
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: passo 2, immagine 1 di 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: passo 4, immagine 1 di 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: passo 5, immagine 1 di 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: passo 6, immagine 1 di 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: passo 7, immagine 1 di 1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: passo 8, immagine 1 di 1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: passo 9, immagine 1 di 1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: passo 10, immagine 1 di 1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: passo 11, immagine 1 di 1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: passo 12, immagine 1 di 1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: passo 13, immagine 1 di 2 Dell Inspiron 11 i3147 Camera Replacement: passo 13, immagine 2 di 2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: passo 15, immagine 1 di 1
    • Use a plastic opening tool to take the camera module off the display.
Conclusione
Muhammad Erchid
Membro da: 10/09/18
1.051 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G6, Leahy Fall 2018 Membro di USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 209
