Salta al contenuto principale
Dell Inspiron 11 3169 Display Hinges Replacement
Cosa ti serve
  1. Dell Inspiron 11 3169 Display Hinges Replacement, Peel the Tapes: passo 1, immagine 1 di 2 Dell Inspiron 11 3169 Display Hinges Replacement, Peel the Tapes: passo 1, immagine 2 di 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
  2. Dell Inspiron 11 3169 Display Hinges Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
  3. Dell Inspiron 11 3169 Display Hinges Replacement, Lifting the Hinges: passo 3, immagine 1 di 2 Dell Inspiron 11 3169 Display Hinges Replacement, Lifting the Hinges: passo 3, immagine 2 di 2
    • Lift the display hinges off the display back-cover and antenna assembly.
  4. Dell Inspiron 11 3169 Display Hinges Replacement, Align the Screw Holes: passo 4, immagine 1 di 1
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
  5. Dell Inspiron 11 3169 Display Hinges Replacement, Replace the Screws: passo 5, immagine 1 di 1
    • Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
  6. Dell Inspiron 11 3169 Display Hinges Replacement, Route the Antenna Cables: passo 6, immagine 1 di 2 Dell Inspiron 11 3169 Display Hinges Replacement, Route the Antenna Cables: passo 6, immagine 2 di 2
    • Route the antenna cables through the routing guide on the hinge cover and secure it in place.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 202
