Salta al contenuto principale
Dell Inspirion 15z-5523 Fan Replacement
Cosa ti serve
  1. Dell Inspirion 15z-5523 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • First turn over your computer and remove all of the rubber stoppers on the back.
  2. Dell Inspirion 15z-5523 Fan Replacement: passo 2, immagine 1 di 1
    • Then remove all the screws that were under the rubber stoppers.
  3. Dell Inspirion 15z-5523 Fan Replacement: passo 3, immagine 1 di 1
    • Take the screw out of the back plate.
  4. Dell Inspirion 15z-5523 Fan Replacement: passo 4, immagine 1 di 1
    • Remove back plate by grabbing and lifting up.
  5. Dell Inspirion 15z-5523 Fan Replacement: passo 5, immagine 1 di 1
    • Remove CD port by pulling it straight out.
  6. Dell Inspirion 15z-5523 Fan Replacement: passo 6, immagine 1 di 1
    • Remove the keyboard.
  7. Dell Inspirion 15z-5523 Fan Replacement: passo 7, immagine 1 di 1
    • Take screw out of the surface below the keyboard and remove the top layer of the computer off of the base.
  8. Dell Inspirion 15z-5523 Fan Replacement: passo 8, immagine 1 di 1
    • Remove the battery by unscrewing the 5 screws and pull straight out.
  9. Dell Inspirion 15z-5523 Fan Replacement: passo 9, immagine 1 di 1
    • Remove the three screws from the hard drive and remove by pulling straight out.
  10. Dell Inspirion 15z-5523 Fan Replacement: passo 10, immagine 1 di 2 Dell Inspirion 15z-5523 Fan Replacement: passo 10, immagine 2 di 2
    • Unscrew motherboard and remove the two clips.
  11. Dell Inspirion 15z-5523 Fan Replacement: passo 11, immagine 1 di 2 Dell Inspirion 15z-5523 Fan Replacement: passo 11, immagine 2 di 2
    • Flip motherboard up, unscrew the three screws, and unclip the fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 812
