Salta al contenuto principale
Dell Inspirion 15z-5523 Battery Replacement
Cosa ti serve
  1. Dell Inspirion 15z-5523 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all rubber stoppers and screw from the back of the laptop
  2. Dell Inspirion 15z-5523 Battery Replacement: passo 2, immagine 1 di 2 Dell Inspirion 15z-5523 Battery Replacement: passo 2, immagine 2 di 2
    • Detach keyboard from the laptop
    • Unscrew 4 screws on the metal frame (yellow circles)
    • Disconnect the 4 data connections (teal arrows)
  3. Dell Inspirion 15z-5523 Battery Replacement: passo 3, immagine 1 di 1
    • Remove top computer frame
  4. Dell Inspirion 15z-5523 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspirion 15z-5523 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the 5 screws that holding the old battery
    • Gently lift up battery and pull it out
Conclusione
2 Commenti
Excellent, Easy to follow and helpful graphics. Thanks
leonard russ - Replica
Hi Christian,
Would you happen to know what are the specs for the seven screws in the base of the Inspiron 15z 5523? Mine is exactly like the one in your post for replacing the battery. I lost mine when replacing the fan. Dell won’t help because the machine is out of warranty. Any ideas would be appreciated.
Thanks Christian.
David
David Sokal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 3,437
