Salta al contenuto principale
Dell G15-5511 Gaming RAM Replacement
Cosa ti serve
  1. Dell G15-5511 Gaming RAM Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Dell G15-5511 Gaming RAM Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming RAM Replacement, Unclip the front corners: passo 2, immagine 1 di 2 Dell G15-5511 Gaming RAM Replacement, Unclip the front corners: passo 2, immagine 2 di 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming RAM Replacement: passo 3, immagine 1 di 2 Dell G15-5511 Gaming RAM Replacement: passo 3, immagine 2 di 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming RAM Replacement, Remove the back cover: passo 4, immagine 1 di 3 Dell G15-5511 Gaming RAM Replacement, Remove the back cover: passo 4, immagine 2 di 3 Dell G15-5511 Gaming RAM Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming RAM Replacement, RAM: passo 5, immagine 1 di 3 Dell G15-5511 Gaming RAM Replacement, RAM: passo 5, immagine 2 di 3 Dell G15-5511 Gaming RAM Replacement, RAM: passo 5, immagine 3 di 3
    • Locate the component in the circle area, the battery connector on the motherboard.
    • Carefully grasp the connector by its side and pull it away from the mother board.
    • Do not apply excessive force since it could damage the connector or the socket.
  6. Dell G15-5511 Gaming RAM Replacement: passo 6, immagine 1 di 3 Dell G15-5511 Gaming RAM Replacement: passo 6, immagine 2 di 3 Dell G15-5511 Gaming RAM Replacement: passo 6, immagine 3 di 3
    • Locate the two RAM slots highlighted by the red rectangles.
    • Locate the metal retaining clip outward, as highlighted by the red rectangles.
    • Carefully grasp the metal retain clips and pull them away from the RAM slot.
  7. Dell G15-5511 Gaming RAM Replacement: passo 7, immagine 1 di 3 Dell G15-5511 Gaming RAM Replacement: passo 7, immagine 2 di 3 Dell G15-5511 Gaming RAM Replacement: passo 7, immagine 3 di 3
    • Once the clips are released, carefully pull the module out of the slot.
    • When installing the new RAM, align the notches on the RAM module with the gap in the slot.
    • Push down the RAM until the metal retaining clip snaps into place, retaining the RAM.
    • If you have a second RAM that you want to be replaced, simply repeat the Step 2 and Step 3.
  8. Dell G15-5511 Gaming RAM Replacement: passo 8, immagine 1 di 3 Dell G15-5511 Gaming RAM Replacement: passo 8, immagine 2 di 3 Dell G15-5511 Gaming RAM Replacement: passo 8, immagine 3 di 3
    • Reconnect the Battery to the motherboard.
    • Using a screwdriver to secure the battery connector, carefully push forward the top part of the battery connector.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Hang Bao
Membro da: 10/23/23
136 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 48
Tutti i Tempi: 357
