Salta al contenuto principale
Dell E193FPc Display Bezel Replacement
Cosa ti serve
  1. Dell E193FPc Display Bezel Replacement, Stand: passo 1, immagine 1 di 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: passo 2, immagine 1 di 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: passo 3, immagine 1 di 2 Dell E193FPc Display Bezel Replacement, Display Bezel: passo 3, immagine 2 di 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: passo 4, immagine 1 di 2 Dell E193FPc Display Bezel Replacement: passo 4, immagine 2 di 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: passo 5, immagine 1 di 3 Dell E193FPc Display Bezel Replacement: passo 5, immagine 2 di 3 Dell E193FPc Display Bezel Replacement: passo 5, immagine 3 di 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 5-36, Amido Fall 2011 Membro di Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,273
