Salta al contenuto principale
Dell Dimension 4600 Side Panel Replacement
  1. Dell Dimension 4600 Side Panel Replacement, Side Panel: passo 1, immagine 1 di 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Side Panel Replacement: passo 2, immagine 1 di 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Side Panel Replacement: passo 3, immagine 1 di 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team 6-10, Regan Fall 2011 Membro di Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membri
11 Guide realizzate
2 Commenti
I can't get the panel off
Diego Vega - Replica
Thanks, worked perfectly, very much appreciated!
Bodhi Goforth - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 33
Tutti i Tempi: 22,139
