Salta al contenuto principale
Dell Dimension 4600 Fan Replacement
  1. Dell Dimension 4600 Fan Replacement, Side Panel: passo 1, immagine 1 di 1
    • Locate the case cover latch on the back of the computer.
    Chiedi a FixBot
  2. Dell Dimension 4600 Fan Replacement: passo 2, immagine 1 di 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    Chiedi a FixBot
  3. Dell Dimension 4600 Fan Replacement: passo 3, immagine 1 di 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
    Chiedi a FixBot
  4. Dell Dimension 4600 Fan Replacement, Fan: passo 4, immagine 1 di 1
    • Lay the computer flat on it's side so that you are looking down at all of the components.
    • Locate the fan and its black, red, and white power cable.
    Chiedi a FixBot
  5. Dell Dimension 4600 Fan Replacement: passo 5, immagine 1 di 1
    • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
    Chiedi a FixBot
  6. Dell Dimension 4600 Fan Replacement: passo 6, immagine 1 di 1
    • Locate the release clip on the side of the fan and hold it down with your thumb.
    Chiedi a FixBot
  7. Dell Dimension 4600 Fan Replacement: passo 7, immagine 1 di 1
    • While holding the release clip down, look on the outside of the case where the fan lies.
    • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
    Chiedi a FixBot
Conclusione
Altre 4 persone hanno completato questa guida.
Tim
Membro da: 10/12/11
76 Reputazione
Una guida realizzata
Cal Poly, Team 6-10, Regan Fall 2011 Membro di Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membri
11 guide realizzate
1Commento della guida
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 84
Tutti i Tempi: 6,488
