Salta al contenuto principale
Dell Dimension 2300 Hard Drive Replacement
Cosa ti serve
    • Shut down the computer through the Start menu.
    • Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
    • Remove the bracket-securing screw, and then remove the drive bracket from the computer.
    • Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
    • Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
Conclusione
Altre 5 persone hanno completato questa guida.
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
2 Commenti
Some pictures would be nice.
guardian10 - Replica
No power arrived while i switch on the button of compiutor
Daniel Hailemariam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 91
Tutti i Tempi: 1,907
