Salta al contenuto principale
Introduzione
This guide will show you how to remove and replace the charging port for your Chromebook 3180.
  1. Remove the 7 screws from the back cover with a Phillips #0 screwdriver Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
  2. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  3. Secure all 7 screws with a Phillips #0
    • Secure all 7 screws with a Phillips #0
Conclusione
Altre 2 persone hanno completato questa guida.
Jon
Membro da: 18/08/2013
2.869 Reputazione
18 Guide realizzate
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 388
