Salta al contenuto principale
Dell Chromebook 3180 Charging Port Replacement
Cosa ti serve
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: passo 1, immagine 1 di 2 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: passo 1, immagine 2 di 2
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: passo 5, immagine 1 di 1
    • Secure all 7 screws with a Phillips #0
Conclusione
Altre 4 persone hanno completato questa guida.
Jon
Membro da: 08/18/13
3.921 Reputazione
22 Guide realizzate
Un commento
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,069
