Salta al contenuto principale
Dell Chromebook 3110 Battery Replacement
Cosa ti serve
  1. Dell Chromebook 3110 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Battery Replacement: passo 2, immagine 1 di 1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Battery Replacement: passo 3, immagine 1 di 1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Battery Replacement: passo 4, immagine 1 di 1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Battery Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
Conclusione
Anna K Tomko
Membro da: 02/24/23
136 Reputazione
1 Guida realizzata
Marist, Team 1-6, Chaterdon Spring 2023 Membro di Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 242
