Introduzione
This is a guide on how to remove the IO Board on a Dell Chromebook 3100.
Please note that the battery removal is not required for this guide, but it is strongly recommended.
Cosa ti serve
Flip the laptop so the bottom is facing upwards.
Loosen the nine screws from the back panel using a Phillips #0 screwdriver.
Remove the screws attached to the battery using a Phillips #0 screwdriver.
Disconnect the battery from the motherboard by gently pulling on the connector cable at the top of the battery.
Remove the screws from the IO Board using a Phillips #0 screwdriver.
Carefully disconnect the IO power cable labeled with "IO" and "MB."
To reassemble your device, follow these instructions in reverse order with the new IO Board.
