Salta al contenuto principale
Dell Chromebook 3100 2-in-1 Webcam Replacement
Cosa ti serve
  1. Dell Chromebook 3100 2-in-1 Webcam Replacement, Webcam: passo 1, immagine 1 di 1
    • Using a Phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 2, immagine 1 di 1
    • Using a jimmy and remove the plastic covering to reveal internal hardware.
  3. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 3, immagine 1 di 1
    • Unplug the battery from the motherboard by pulling gently.
  4. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 4, immagine 1 di 1
    • Remove the single screw (M2x3).
    • Remove the bracket over the Wi-Fi and camera plugs.
  5. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 5, immagine 1 di 1
    • Unplug the now revealed camera and Wi-Fi antennas by gently pulling.
  6. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 6, immagine 1 di 1
    • Remove the single screw (M2x4).
    • Remove the bracket over the display cable.
  7. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 7, immagine 1 di 1
    • Lift the black tab and gently pull on the display cable to disconnect it.
  8. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 8, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 8, immagine 2 di 2
    • Remove the 6 screws (M2.5x5) holding the hinges on both ends.
    • When both brackets are free, separte the screen from the computer screen from the bottom section.
  9. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 9, immagine 1 di 1
    • Use a jimmy to pry between the 2 layers of the now disconnected display.
  10. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 10, immagine 1 di 1
    • Unplug the webcam by gently pulling on the cable shown.
  11. Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 11, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: passo 11, immagine 2 di 2
    • Use a jimmy to pry up the webcam, which is to then be removed.
Conclusione
ot moya
Membro da: 11/09/23
481 Reputazione
3 Guide realizzate
IUPUI, Team 3-2, Harley Fall 2023 Membro di IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 154
