Salta al contenuto principale
Dell Chromebook 3100 2-in-1 Display Replacement
Cosa ti serve
  1. Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Display Replacement: passo 2, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement: passo 2, immagine 2 di 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Display Replacement, Battery: passo 3, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Display Replacement: passo 4, immagine 1 di 3 Dell Chromebook 3100 2-in-1 Display Replacement: passo 4, immagine 2 di 3 Dell Chromebook 3100 2-in-1 Display Replacement: passo 4, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Display Replacement: passo 5, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement: passo 5, immagine 2 di 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Display Replacement, Display: passo 6, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement, Display: passo 6, immagine 2 di 2
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  7. Dell Chromebook 3100 2-in-1 Display Replacement: passo 7, immagine 1 di 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  8. Dell Chromebook 3100 2-in-1 Display Replacement: passo 8, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement: passo 8, immagine 2 di 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  9. Dell Chromebook 3100 2-in-1 Display Replacement: passo 9, immagine 1 di 1
    • Open the system to 180 degrees and place the computer on a flat surface, with the display hinges facing up.
  10. Dell Chromebook 3100 2-in-1 Display Replacement: passo 10, immagine 1 di 3 Dell Chromebook 3100 2-in-1 Display Replacement: passo 10, immagine 2 di 3 Dell Chromebook 3100 2-in-1 Display Replacement: passo 10, immagine 3 di 3
    • Remove the three (on both hinges) 5 mm display hinge bracket screws that secure the display assembly to the system using a Phillips #1 screwdriver.
  11. Dell Chromebook 3100 2-in-1 Display Replacement: passo 11, immagine 1 di 1
    • Remove the display assembly from the system.
  12. Dell Chromebook 3100 2-in-1 Display Replacement: passo 12, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement: passo 12, immagine 2 di 2
    • Use the opening tool to open the display panel starting from the pry points located above the left and right hinges.
    • Work your way around, through the left and right side of the panel, and carefully flip the display panel over.
  13. Dell Chromebook 3100 2-in-1 Display Replacement: passo 13, immagine 1 di 2 Dell Chromebook 3100 2-in-1 Display Replacement: passo 13, immagine 2 di 2
    • Peel back the adhesive tape securing the display cable on the back of the display panel and separate the display.
Conclusione
M Ali
Membro da: 11/03/21
301 Reputazione
2 Guide realizzate
Gateway, Team 1-1, Pee Fall 2021 Membro di Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,659
