Salta al contenuto principale
Dell Chromebook 13-7310 Network Card Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 Network Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: passo 3, immagine 1 di 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: passo 4, immagine 1 di 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: passo 5, immagine 1 di 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: passo 6, immagine 1 di 2 Dell Chromebook 13-7310 Network Card Replacement, Network Card: passo 6, immagine 2 di 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: passo 7, immagine 1 di 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: passo 8, immagine 1 di 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
Conclusione
Brett Raymond
Membro da: 11/01/18
469 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 538
