Salta al contenuto principale
Dell Chromebook 13-7310 Mousepad Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 Mousepad Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 Mousepad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Mousepad Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: passo 3, immagine 1 di 3 Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: passo 3, immagine 2 di 3 Dell Chromebook 13-7310 Mousepad Replacement, Mousepad: passo 3, immagine 3 di 3
    • The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side.
    • Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard.
    • To remove the battery, lift up on one side to get you fingers underneath and lift away.
  4. Dell Chromebook 13-7310 Mousepad Replacement: passo 4, immagine 1 di 3 Dell Chromebook 13-7310 Mousepad Replacement: passo 4, immagine 2 di 3 Dell Chromebook 13-7310 Mousepad Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the six 2mm screws located around the maouse pad cover.
    • Using either fingernails or tweezers, lift the black cover on the ribbon cable and pull the cable loose from he motherboard.
    • Once the ribbon cable is disconnected lift up on the back cove to remove it and expose the mouse pad.
  5. Dell Chromebook 13-7310 Mousepad Replacement: passo 5, immagine 1 di 1
    • Now that the mouse pad is exposed, lift the assembly to remove the mouse pad.
Conclusione
Congratulations! You have successfully removed the mouse pad on your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 566
