Salta al contenuto principale
Dell Chromebook 13-7310 Motherboard Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Motherboard Replacement, Battery: passo 3, immagine 1 di 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Motherboard Replacement: passo 5, immagine 1 di 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Motherboard Replacement, Network Card: passo 6, immagine 1 di 2 Dell Chromebook 13-7310 Motherboard Replacement, Network Card: passo 6, immagine 2 di 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Motherboard Replacement: passo 7, immagine 1 di 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Motherboard Replacement: passo 8, immagine 1 di 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Dell Chromebook 13-7310 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Gently pull to unplug fan connector.
  10. Dell Chromebook 13-7310 Motherboard Replacement: passo 10, immagine 1 di 2 Dell Chromebook 13-7310 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove 4 screws securing heat sink.
  11. Dell Chromebook 13-7310 Motherboard Replacement: passo 11, immagine 1 di 1
    • Lift away heat sink.
  12. Dell Chromebook 13-7310 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Dell Chromebook 13-7310 Motherboard Replacement: passo 13, immagine 1 di 1
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Dell Chromebook 13-7310 Motherboard Replacement: passo 14, immagine 1 di 1
    • Gently remove the cable.
  15. Dell Chromebook 13-7310 Motherboard Replacement: passo 15, immagine 1 di 1
    • Pull up on connector tab to release IO board cable.
  16. Dell Chromebook 13-7310 Motherboard Replacement: passo 16, immagine 1 di 2 Dell Chromebook 13-7310 Motherboard Replacement: passo 16, immagine 2 di 2
    • Pull up on connector tab to release touchpad cable.
  17. Dell Chromebook 13-7310 Motherboard Replacement: passo 17, immagine 1 di 1
    • Release the keyboard backlight cable.
  18. Dell Chromebook 13-7310 Motherboard Replacement: passo 18, immagine 1 di 2 Dell Chromebook 13-7310 Motherboard Replacement: passo 18, immagine 2 di 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Dell Chromebook 13-7310 Motherboard Replacement: passo 19, immagine 1 di 1
    • Release eDP cable.
  20. Dell Chromebook 13-7310 Motherboard Replacement: passo 20, immagine 1 di 1
    • Release dc-in cable.
  21. Dell Chromebook 13-7310 Motherboard Replacement: passo 21, immagine 1 di 1
    • Gently lift up the motherboard to remove it.
Conclusione
Brett Raymond
Membro da: 11/01/18
469 Reputazione
3 Guide realizzate
Un commento
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 898
